3 Replies Latest reply on Dec 7, 2016 9:36 AM by Mathieu Jette
    API/Macro, Multi pages drawing, tables problem.
    Mathieu Jette
           We are using a macro for batch print and inputs of properties in the drawings as they are being printed.
      When a drawing has multiple pages (1 for each configuration of the assembly/part), the macro scans the bom to identify the page to print (as far as how I understand it).
      It works well untill there is another table (revision, or plain table) in the sheet... if so, then the macro crashes.
      I need help to fix this issue.
      Here is the Macro Section concerned. with the line where it crashes identified.
      Set swFeatMgr = Sw_model.FeatureManager
      Bon_Sheet = False
      Sw_Sheets = Sw_Draft.GetSheetNames
      N_Sheet = 1
      If Sw_Draft.GetSheetCount = 1 Then GoTo Pass_Sheet
      For J = 0 To UBound(Sw_Sheets)
          bRet = Sw_Draft.ActivateSheet(Sw_Sheets(J))
          Set Sw_Sheet = Nothing
          Set Sw_Sheet = Sw_Draft.Sheet(Sw_Sheets(J))
          Set Sw_View = Sw_model.GetFirstView
          Do While Not Sw_View Is Nothing
              Set SwAll_table = Sw_View.GetFirstTableAnnotation
              Do While Not SwAll_table Is Nothing
                  Set Sw_Bom = Nothing
                  Set Sw_Bom = SwAll_table
                  Set Sw_Bom_Feature = Nothing
                  Set Sw_Bom_Feature = Sw_Bom.BomFeature                                    'Crash happens here
                  Names = Sw_Bom_Feature.GetConfigurations(True, Visible)
                  If Names(0) = Config_Name Then
                      Bon_Sheet = True
                      Exit Do
                  Set SwAll_table = SwAll_table.GetNext
              Loop
              If Bon_Sheet = True Then
                  Exit Do
              bolUseParentStyle = Sw_View.GetUseParentDisplayMode()
              lngDisplayMode = Sw_View.GetDisplayMode2
              bolDispEdgesInShadedMode = Sw_View.GetDisplayEdgesInShadedMode
              bolResult = Sw_View.SetDisplayMode3(bolUseParentStyle, lngDisplayMode, False, bolDispEdgesInShadedMode)
              Set Sw_View = Sw_View.GetNextView
          Loop
              Exit For
          N_Sheet = N_Sheet + 1
      Next J
      Any help will be appreciated.
      Thanks.
        • Re: API/Macro, Multi pages drawing, tables problem.
          Peter Brinkhuis
          I don't really understand what the macro does exactly. I see it goes through the sheets, through the views and the tables.
          I think you have to check the type of the table annotation using 2015 SOLIDWORKS API Help - Type Property (ITableAnnotation)  . If it's a bill of materials, you can run the line that 'crashes' with other table types. If it's another type of table, you just skip it.
            Josh Brady
            As Peter mentioned, you do need to check the table type before assuming it's a BOM:
            Bon_Sheet = False
            N_Sheet = 1
                           if SwAll_table.Type = swTableAnnotation_BillOfMaterials then
                            Bon_Sheet = True
                            Exit Do
                    Loop
                        Exit Do
                Loop
                    Exit For
            Next J
