Hello, I am trying to wrap a cured line 360 around a conical surface but I have no idea how to do it.
I need to recreate this blender.
Here is what I currently have set up.
The piece I currently have modeled is the inside grey part and I want to emboss the curve above and connect to the sketch below with a loft. The rear of the blender does not have the curve.
Edit: Uploaded pics directly
The way I'd tackle this is to draw a curve on the upper plane you have shown and project it down to split the surface of the cone. Looking at this, the "vertical" lines would project to straight lines (radii) on the plane with the upper (left) and lower (center) curves being some circle/parabola/polynomial curve.
If the part is already modeled you could place a plane on top and project/convert-edge the shape up to the plane.
