What happened here? I want my dimensions back!!!
Thie preview shows the dimensions saved in the file. It worked before the upgrade. See the thumbnail on the right.
When end I open the file, the dimensions are shown for half a second, then a prompt flashes "Rendering" and the dimensions disappear.
See below.
Is there a new setting for dimensions' visibility, or is this a new regression?
Using iOS 10 on iPad Pro 9.7.
Update.
Did is a bit more testing and I found that the behaviour is not consistent.
Some eDrawings show DimXpert dimensions, while other have stopped showing them. If I load the actual sldprt file, the dimensions are shown; if I load the eDrawing that used to work fine 2 weeks ago, it does not work.
Could you please test the two attached files?
I tested on an iPad Pro 9.7 iOS 10 and an iPad 4 iOS 9.
