Hi I'm learning Solid Works. I'm not sure how to creation relationships between geometries in two different sketches. I noticed that when I'm working in one sketch I can just hold down shift, click another element, and then define relations. But when I need a relation between two elements on two different sketches (same part), I'm not sure how to do that.
Any help is appreciated
Rick
You should be able to do that in the same way. While editing sketch 2, you should be able to select elements of sketch 1 and add relations and dimensions. You may have to show sketch 1 first though, if it is hidden. And you have to be in "edit sketch mode".
