Sorry, this is a really simple question about the ever frustrating interface of Solidworks 2013.
If I choose Move Component->Rotate Component in an Assembly
I can rotate the Component by Delta XYZ by the right number of degrees but this rotation is limited to rotating around the origin axis.
I want to do a rotation About Entity. I can pick the axis I want to rotate about, but the solidworks interface only allows me to rotate with Standard Drag, Collision Detection, or Physical Dynamics.
I want to instead be able to rotate 180 degrees About my axis, but I cannot do this with free drag as it gives me an inaccurate rotation.
How do I rotate by a certain number of degrees about an axis I choose?
-D
Are you working this problem in an assembly? Or is this a Part question?
Steve C
