Scenario: Open Solidworks, Select to Create a new Part.
Save the Part to PDM Vault.
a. Using Admin Login and Other users as well, When a File is saved into a configured Vault, the Data Card related to the File Type extension Pops Up.
b. But for a Particular user, even through "Solidworks PDM Client" Add-in is enables in Tools > Options > Add-Ins, the DataCard does not Pop-Up.
So I have the DataCard set for Solidworks Part, Drawing and Assembly files.
Is there anything that I am missing?
Thank You,
Vineet
Hi Vineet, on the user's machine, in SolidWorks, check Tools, SolidWorks PDM, Options, Server, Show File Data Card when card is saved
If this is enabled and the data card is still not popping up then perhaps check the user's permissions particualrly with regards to saving files and having permissions to access data cards.
Hope this helps
Prasad
