I've been doing a series of 2-d drawings, and I've been told that the drawings weren't coming through because they were to big. I've been going through these drawings, which I had set to B size, or C size, but when I measure the title block instead of it being 11x17, or 18x24 the title blocks are 128x168. I've tried changing the title block size in the properties, but I still don't get standard sized title block. Also I made a couple new 2-d files used SW title blocks, and all those were the standard sizes. Is this some kind of scaling thing?
Not sure why Solidworks does this but setting it where you did has no affect of paper size. But if you right click go to properties and set your size this will work.
