3 Replies Latest reply on Nov 29, 2016 5:10 PM by Viktor Bovzdarenko
    "Compile Error: Sub or Function Not Defined"
    Andrew Wallace
      I am trying to write an extremely basic Macro and it is giving me fits. I just want a user form that will allow the user to input the length and diameter of a cylinder and SolidWorks draw and extrude it for them. I literally watched a step by step tutorial and almost copied the code word for word but it is giving me the error "Compile Error: Sub or Function Not Defined". I have absolutely no idea why it isn't working but this is my first time writing a macro code for SolidWorks so it could be something blatantly obvious that I am missing. Any help would be greatly appreciated.
      Here is my code:
      ' C:\Users\awallace\AppData\Local\Temp\swx1764\Macro1.swb - macro recorded on 11/28/16 by awallace
      Dim swApp As Object
      Dim Part As ModelDoc2
      Dim boolstatus As Boolean
           'Display User Form
           UserForm1.Show
           'Opens new part in SolidWorks
           Set Part = swApp.NewDocument("C:\ProgramData\SolidWorks\SOLIDWORKS 2015\templates\Part.prtdot", 0, 0, 0)
           swApp.ActivateDoc2 "Part2", False, longstatus
           Set Part = swApp.ActiveDoc
           Dim myModelView As Object
           Set myModelView = Part.ActiveView
           myModelView.FrameState = swWindowState_e.swWindowMaximized
           boolstatus = Part.Extension.SelectByID2("Front Plane", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
           Part.SketchManager.InsertSketch True
      Public Sub CreateCylinder(InputLength As Double, InputDia As Double)
          'Define Variables
          Dim CylinderLength As Double
          Dim CylinderDia As Double
          'Inputs User Values
          CylinderLength = InputLength
          CylinderDia = InputDia
          'Convert to Meters
          CylinderLength = ConvertToMeters(CylinderLength)
          CylinderDia = ConvertToMeters(CylinderDia)
          'Creating the SketchManager
          Dim swSketchManager As SketchManager
          Set swSketchManager = Part.SketchManager
          'Create Circle
          Dim TheCircle As SketchSegment
          Set TheCircle = swSketchManager.CreateCircle(0, 0, 0, CylinderDia / 2, 0, 0)
          Dim swFeatureManager As FeatureManager
          Set swFeatureManager = Part.FeatureManager
          'Create Circle
          Dim TheLength As Feature
          Set TheLength = swFeatureManager.FeatureExtrusion2(True, False, False, swEndCondBlind, swEndCondBlind, CylinderLength, 0, False, False, False, False, 0, 0, False, False, False, False, False, False, False, False, False, False)
      Here is also the code for the userform:
      Private Sub CommandButton1_Click()
          'Create Variables
          Dim Length As Double
          Dim Dia As Double
          'Set User Inputs Equal to Variables
          Length = LengthTextBox.Text
          Dia = DiaTextBox.Text
          Call CreateCylinder(Length, Dia)
          End
        • Re: "Compile Error: Sub or Function Not Defined"
          Viktor Bovzdarenko
          Hi Andrew
          Looks like ConvertToMeters is not defined anywhere
          instead of
          try to use
               CylinderLength = CylinderLength/1000 'Converts from mm to m
               CylinderDia = CylinderDia/1000 'Converts from mm to m
          or define the function ConvertToMeters somewhere:
          Function ConvertToMeters (dblVal As Double) As Double
               ConvertToMeters  = dblVal /1000
          End Function
          Instead of 1000 there should be any other conversion coefficient (1000 is from mm to m, any other could be used to convert from imperial)
