InsertModelAnnotations3
Question asked by Yong Ning on Nov 27, 2016
Latest reply on Nov 27, 2016 by Yong Ning
Options
Include items from hidden features. Inserts model items for hidden features. Clear this option to prevent the insertion of annotations that belong to hidden model items. Performance is slower while hidden model items are filtered.
Use dimension placement in sketch. Inserts model dimensions from the part in the same locations in the drawing.
Private Sub ll()
    Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
        Set SwApp = Application.SldWorks
        Set SwModel = SwApp.ActiveDoc
    Dim SwDraw As DrawingDoc
        Set SwDraw = SwModel
    Dim SwSelMgr As SelectionMgr
        Set SwSelMgr = SwModel.SelectionManager
    Dim SwView As View
        Set SwView = SwSelMgr.GetSelectedObject5(1)
    Dim Anns, Tmp
        Anns = SwDraw.InsertModelAnnotations3(0, 1737215, True, True, True, True)
        'Anns = SwDraw.InsertModelAnnotations3(0, 1212425, False, True, False, True)
        'Anns = SwDraw.InsertModelAnnotations3(0, swInsertDimensionsMarkedForDrawing, False, True, False, True)
        Stop
Function BreakOut(SwDraw As DrawingDoc, SwView As View)
    Dim Var, vPos, tmp, oScale
        oScale = 1 / SwView.ScaleDecimal
    Dim SwDim As Dimension, Depth
    Dim SwModel As ModelDoc2
        Set SwModel = SwView.ReferencedDocument
        Debug.Print SwModel.GetPathName
        'PrintModelDimension SwModel
        Set SwDim = SwModel.Parameter("Depth@PlateSize") '("Depth@PlateSize")
        Depth = SwDim.Value
    Dim x1 As Double, y1 As Double, x2 As Double, y2 As Double
        With SwDraw
             Var = SwView.GetOutline
             vPos = SwView.Position
             For ii = 0 To UBound(Var)
                 Var(ii) = oScale * Var(ii)
                 If ii < 2 Then
                    vPos(ii) = oScale * vPos(ii)
             Next ii
             tmp = .SketchRectangle(-Var(2), -Var(3), 0, Var(2), Var(3), 0, 1)
             .CreateBreakOutSection Depth / 1000
          End With
End Function
Private Sub del20161124()
   Dim Xls As Excel.Application, Rng As Range
       Set Xls = GetObject(, "Excel.Application")
       Set Rng = Xls.Cells(1, 1)
   Dim ModelName, ViewName, Xx, Yy, Str
       ModelName = Rng(1, 1)
       ViewName = Rng(1, 2)
       Xx = Rng(1, 3) / 1000
       Yy = Rng(1, 4) / 1000
       'Debug.Print Rng.Address, Rng
   Dim SwView As View
       Set SwView = SwDraw.CreateDrawViewFromModelView2(ModelName, ViewName, Xx, Yy, 0)
       BreakOut SwDraw, SwView
       'Debug.Print SwModel.GetPathName
   Dim Annotations As Variant, SwAnn As Annotation
   Dim SwDispDim As DisplayDimension, SwDim As Dimension
       boolstatus = SwDraw.Extension.SelectByID2(SwView.Name, "DRAWINGVIEW", 0.08943651860342, 0.1646920297141, 0, True, 0, Nothing, 0)
       Annotations = SwDraw.InsertModelAnnotations3(0, 32776, False, False, True, True)
       SwDraw.ClearSelection2 True
       For ii = 0 To UBound(Annotations)
           Set SwAnn = Annotations(ii)
           'Debug.Print SwAnn.GetName
           'SwAnn.IGetDisplayData
           Set SwDispDim = SwAnn.GetSpecificAnnotation
           Set SwDim = SwDispDim.GetDimension
           If Not SwDim.FullName Like "*DrwDim*" Then
                SwAnn.Select True
           Else
                SwDispDim.CenterText = True
                Debug.Print SwDispDim.GetDimension.FullName
       Next ii
       Stop
       SwModel.EditDelete
Private Sub del20161127()
       SwModel.ClearSelection
   Dim SwView As View, vViewName
       vViewName = "壳体主视图"
       'tmp = SwDraw.Extension.SelectByID2(vViewName, "DRAWINGVIEW", 0#, 0#, 0, True, 0, Nothing, 0)
       'Set SwView = SwSelMgr.GetSelectedObject5(1)
       'Debug.Print SwView.Name
       boolstatus = SwDraw.Extension.SelectByID2(vViewName, "DRAWINGVIEW", 0#, 0#, 0, True, 0, Nothing, 0)
       'swInsertDimensionsNotMarkedForDrawing
                SwAnn.Select True
           Else
       Next ii
       Stop
       SwModel.EditDelete
