Hi there. my screen is flashing. its like the design tree manager is switching on and off at a high frequency. is there any suggestions? i run a quadro K1200 card
No.It will start while a part or an assembly is in progress. the tab for the fetcher manager is opening an closing rapidly.
Try Resetting SOLIDWORKS Windows Registry as it might help fixing the issue. Please take backup of your settings.
Thanks for that ill give it a go.
Does this happens after you open a file? Check if the F9 key on the keyboard has left pressed?
