I would like to model the following fork.
It would be straight forward if it were the top surface was at right angles with a corner fillet. However, as you can see from the cross section sketch, the neck and prongs have a rounded profile on the top.
I have found the following model GrabCAD - CAD library but without that rounded surface, it's not really what I want.
Is there a way of achieving this in SW?
Ross this model is certainly doable in Solidworks. To make the rounded cross section first you have to model a flat fork after that a combination of boundary surfaces on top can be modeled to achieve the rounded profile. The hard part is decomposing the outline of the fork to achieve smooth surfaces.
