Justin Logan
Print Task Issues
Discussion created by Justin Logan on Nov 24, 2016
For the last few years, some of our computers would not print when the Print Task was executed. The oddest part about it would be, after an update, some computers would be begin to be able to execute the Print Task and others would stop. After some serious digging this week, the root cause was found and solved! The printer selection is case sensitive; i.e. the printer defined in the Task did not match the exact uppercase and lowercase format of the printers installed on some of our computers. This explains why Task execution would stop working, or start working, after updates that affected installed printers - Windows seems to be somewhat inconsistent with naming Printers when they get added or updated.
I updated the GetPrinter function in the Print Task script as follows:
Function GetPrinter(paperSize)
'Dims defined for case sensitive printer check
Dim WshNetwork As Object
Dim Printers As Object
Dim printer As Variant
    If [__printer_prseltype] = 2 Then
        Select Case paperSize
            Case 0
                GetPrinter = "[__printer_papsize_A]"
            Case 1
            Case 2
                GetPrinter = "[__printer_papsize_B]"
            Case 3
                GetPrinter = "[__printer_papsize_C]"
            Case 4
                GetPrinter = "[__printer_papsize_D]"
            Case 5
                GetPrinter = "[__printer_papsize_E]"
            Case 6
                GetPrinter = "[__printer_papsize_A0]"
            Case 7
                GetPrinter = "[__printer_papsize_A1]"
            Case 8
                GetPrinter = "[__printer_papsize_A2]"
            Case 9
                GetPrinter = "[__printer_papsize_A3]"
            Case 10
                GetPrinter = "[__printer_papsize_A4]"
            Case 11
            Case 12
                GetPrinter = "[__printer_papsize_DEF]"
        End Select
    Else
        GetPrinter = "[__printer_prname]"
'Checking installed printers for match with PDM Task defined printer
Set WshNetwork = CreateObject("WScript.Network")
Set Printers = WshNetwork.EnumPrinterConnections
For Each printer In Printers
    If UCase$(GetPrinter) = UCase$(printer) Then
        GetPrinter = printer
        Exit For
Next
End Function
