Activate configuration that appears in drawing view, prior to saving drawing and model with custom name.
Question asked by Brian Eastman on Nov 22, 2016
Latest reply on May 9, 2017 by Quentin Torgerson
I currently have a Macro that successfully opens a part from a view on a drawing, takes information from that parts data card, and uses it to save both the part and the drawing with a custom name. Unfortunately, if that part has multiple configurations it doesn't necessarily open the correct configuration before extracting the data and outputting the file. I need a way to ensure the model configuration that's active is the configuration that appears in the drawing's view.
The code that I currently have to get my swModel set is:
Dim swApp           As SldWorks.SldWorks
Dim swModel         As SldWorks.ModelDoc2
Dim swDrawModel     As SldWorks.ModelDoc2
Dim swDraw          As SldWorks.DrawingDoc
Dim swView          As SldWorks.View
Dim swConfig        As SldWorks.Configuration
Dim swConfName      As Variant
Dim BioNexPN        As String
Dim swRev           As String
Dim FilePath        As String
Dim FileName        As String
Dim PDF             As String
Dim AdobePath       As String
Dim Response        As Integer
Dim bool            As Boolean
'Set activive document as referenes
    Set swDrawModel = swApp.ActiveDoc
' Check to see if a drawing is loaded.
    If swDrawModel Is Nothing Then
        MsgBox "A released solidworks drawing must be open."
        Exit Sub
    If swDrawModel.GetType <> swDocDRAWING Then
        MsgBox "A solidworks drawing must be open and active to run this Macro."
        Exit Sub
'Define the OUTPUT file path
    FilePath = Left(swDrawModel.GetPathName, InStrRev((swDrawModel.GetPathName), "\")) + "OUTPUT FILES\"
'Check if "OUTPUT FILES" folder exists
    If FileOrDirExists(FilePath) = False Then
        MsgBox "Please create 'OUTPUT FILES' sub folder"
        Exit Sub
'Get referenced 3D model
    Set swDraw = swDrawModel
    Set swView = swDraw.GetFirstView
    Set swView = swView.GetNextView
    Set swModel = swView.ReferencedDocument
