Does any one know how to do "Excluded from BOM" on selected item, so that the item will not be displayed in BOM in assembly drawing?
Thanks.
Thanks.
Jim,
Thank you very much.
Also, there is a "Envelop" located upper of "Excluded from BOM". What it does?
Yan
Envelope will also exclude the component from the BOM. It will also remove the weight of the component from the mass of the assembly. It kind of makes the component not be there except for visually where the item shows as transparent. If an item is in an envelope it will not show in drawings unless the view is set to show envelopes, something I had a few problems with initially.
Select the item either in the model tree on on the screen. Right mouse button and go to properties. At the lower right side is "exclude from BOM".
