I have two very similar assemblies. Parts in each assembly are in the same position.
Scene is the same, lights also the same, render options identical (brightness, reflectivity and so on).
But renderings of both assemblies are different, one is very clear and good, second is darker, like "foggy"? Please look below.
Why? Did I missed something? Can I transfer all render parameters (scene, lights) from assembly A to B?
Hi
Did you render on the same computer and the same SW installation?
Once I had the same problem, but never so extreme... I rendered on two different computers and in the photoview options there was a different gamma value.
Maybe it helps.
Kevin
