I am trying to "check in" the file through API in SolidworksWPDM 2012 version and I am getting this error. Please find the below api code used:
Dim con As PDMWConnection
con = CreateObject("PDMWorks.PDMWConnection")
con.Login("pdmwadmin", "pdmwadmin", "localhost")
Dim filename As System.String = "D:\VaultData\projects"
Dim project As System.String = "test"
Dim Number As System.String = Nothing
Dim Description As System.String = Nothing
Dim note As System.String = Nothing
Dim i_revOption As PDMWRevisionOptionType = Nothing
Dim Revision As System.String = Nothing
Dim lifecycle As System.String = Nothing
Dim RetainOwnership As System.Boolean = Nothing
Dim References As System.Object = Nothing
Dim value As PDMWDocument = Nothing
value = con.CheckIn(filename, project, number, description, note, i_revOption, revision, lifecycle, RetainOwnership, References)
con.Logout()
Tried the following workarounds but with no result(as per the solidworks forum work around suggested links:
1) Registered C:\Program Files\Common Files\SOLIDWORKS Shared\pdmworks.dll and also set the path in environment variable - system variables.(Checkin to PDMWorks Vault using API error (24)
2).Checked for the version and relative service packs between the server client.
3). Full permission is granted to folder and also to the dll files.
Kindly suggest me the solution to resolve the issue.
Regards
VinaySuresh
Vinay,
Borrow a license for SolidWorks Professional on the PC that is running your code. This solved the issue for me, even after I returned the license... I can't explain why this works, but it does.
