Hello
I wanted to make a heart with lots of hearts in it (i know )
Im having problems getting a thickness on the surfaces.
I have tried doing a complete solid and using shell, but it says that the thicknes value is greater than the minimum radius.
I have tried thicken too, same error. I have removed the split lines and small heart cuts, same error.
Erik.. this can not offset, the corner/points degenerate or are singular.
..I did this with a fill surface and surface extrusions with 5 deg drafts plus a boundary surface to further help the fill blend/drap so it does not have any singularities.
