I wondered if anyone has a good advise on merging multiple sketch segments into a continuous line so to avoid surfaces with multiple faces.
I have attached a little diagram on how I try to use Fit Spline but it makes me nervous when relations to reference geometry are lost.
Thank you,
Anton
My Fit Spline does update. However my "best" practice when working with complex curves is to have two or more separate sketches to control in what order they update. In your case I would make the line segments in Sketch1 and then create Sketch2 containing Fit Spline.
Also when having line/arc segments connected by splines in the same sketch, I sometimes experience that they somehow counteract each other. In such a case I make one sketch with lines/arcs - one with ONLY the splines - one final one with Convert Entities.
