Convert Drawing document (slddrw) to pdf using virtual printer (C#)
Question asked by Bratitsa Vlaids on Nov 18, 2016
Hi guys, I use this code
  1. Process[] processes = Process.GetProcessesByName("SLDWORKS");?
  2.                 foreach (var process in processes)?
  3.                 {?
  4.                     process.Kill();?
  5.                 }?
  6.                 sld = new SldWorks() { Visible = true };?
  7.                 int errors = 0, warnings = 0;?
  8.                 ModelDoc2 swModel = sld.OpenDoc6(@"D:\test drawings\ВНС-900.56.003+.SLDDRW", (int)swDocumentTypes_e.swDocDRAWING, (int)swOpenDocOptions_e.swOpenDocOptions_Silent +(int)swOpenDocOptions_e.swOpenDocOptions_ViewOnly, "", errors, warnings);              ?
  9.                 IDrawingDoc drawingDoc = swModel as IDrawingDoc;?
  10.                 string[] sheetNames = drawingDoc.GetSheetNames();?
  11.                 int sheetsCount = sheetNames.Length;?
  12.                       double[] propertis = null;?
  13. ?
  14.                 Random rnd = new Random();?
  15.                 sld.SetUserPreferenceToggle((int)swUserPreferenceToggle_e.swPageSetupPrinterDrawingScaleToFit, true);?
  16.                 for (int i = 0; i < sheetsCount; i++)?
  17.                 {?
  18.                     drawingDoc.ActivateSheet(sheetNames[i]);?
  19.                     Sheet sheet = drawingDoc.GetCurrentSheet();?
  20.                     PageSetup pagesetup = sheet.PageSetup;?
  21. ?
  22.                    ?
  23.                     pagesetup.Orientation =rnd.Next(1,2);?
  24.                     pagesetup.PrinterPaperSize = rnd.Next(8, 9); ;?
  25. ?
  26.                     (drawingDoc as ModelDoc).PrintOut(i + 1, i + 1, 1, true, "PDFCreator", 1, true);?
  27. ?
  28.                 }
and virtual printer "Bullzip PDF Printer", to convert slddrw assembly into pdf. The file is converted successfully, but the test parameters aren’t applied (It doesn’t change orientation and paper size), despite the fact that a similar script on VBA worked
  1. Set swApp = Application.SldWorks?
  2. Set swDrDoc = swApp.ActiveDoc?
  3. If swDrDoc.GetType <> swDocDRAWING Or swDrDoc Is Nothing Then?
  4.   Exit Sub?
  5. End If?
  6. ?
  7. currSheet = swDrDoc.GetCurrentSheet.GetName?
  8. sheetNames = swDrDoc.GetSheetNames?
  9. ?
  10. For i = 0 To swDrDoc.GetSheetCount - 1?
  11. swDrDoc.ActivateSheet sheetNames(i)?
  12. With swDrDoc.PageSetup?
  13.   .DrawingColor = swPageSetup_BlackAndWhite?
  14.   .Orientation = swPageSetupOrient_Landscape?
  15.   .ScaleToFit = True?
  16.   .HighQuality = True?
  17.   .PrinterPaperSize = 8?
  18.    printer = printerCDE?
  19. End With?
  20. 'Debug.Print "Sheet: " & sheetNames(i) & "    Sheet Size: " & sheetSize & "    Printer: " & printer?
  21. swDrDoc.PrintOut i + 1, i + 1, 1, False, printer, 1, False?
  22. Next i?
  23. swDrDoc.ActivateSheet currSheet
Help me solve this problem please. tnx
ps I know about swExportPDFData.SetSheets (..) => modelDocExtension.SaveAs (..), but in large assemblies, this approach takes a lot of RAM
