Hi
I`m trying to get a mitered corner in a weldment with 2 beam of different size. In the real word this is not a problem, the angle simple will be a 45. But other then making a sketch and cutting each beam to the correct angle, is there a easy way to do it?
I notice the "miter trim plane point" feature, so figured that would solve it. But you can only select a point, not a line or plane, so it give this
Is there any other option to get a proper miter?
The joint should look like this
Personally, in this instance I would cut the parts. You know the exact height/depth of the angle cut so just sketch and cut. You won't get a good match up between each of the flanges but the faces will meet perfectly.
