How can i share a sketch to generate 2 parts ? To modify the sketch and both parts update.
I do a sketch and with it i do a part, but with the same sketch do other parts, actually y copy the sketch, but sometimes if i modify the sketch i forget update the others copies, and it produce a error on the production.
Make one master file with the required sketch and insert that into other parts (using insert part into part). And then when you update master file, rest all should update OR would update when you open them.
