Stop Corner Circles from moving in a sketch when rotating
Question asked by Kray Shivers on Nov 16, 2016
Latest reply on Nov 23, 2016 by Bernie Daraz
I am trying to fix a library feature I created for cutting holes into part for carriage bolts. the issue is that if I put a circular relief in each corner of my base sketch, one of the legs moves, changing the arc length of the relief and changes the profile of the cutout. I need to solve this problem because is takes to many features to create the finished product.
I have tried relations and also have tried putting a construction square underneath as a skeleton but even that didn't work. if anyone has any solution to this issue of some stuff I can try would be extremely helpful. I have included some screen shots as to what I am talking about.Carriage Bolt Hole Pre Rotation.JPG
this is what it should look like. I drew it at an angle to test a theory.
And this is what happens when the feature is rotated. it wouldn't matter what vertex I used, a leg would shift like this.
Thank you all in advance for your help in this matter.
