FBFabio Brandi14/10/2008
Hello everybody,
I have a couple of questions for you SolidWorks gods.
1) Is it possible to mirroring some features inside a SolidWorks assembly?
What I have is an assembly where I need to create some holes. Those holes have to be mirrored from a side to the other one of the assembly itself.
2) Is it possible to get a sweep cut in a SW assembly?
Basically I need to create a rectangular cut with an angle. This angle needs to be on only two sides of the rectangular shape.
I tried to do it using an extruded cut with the draft function turned on, but it does not work because it creates a cut with an angle on the whole four sides of the cut.
Are there some tricks that I can use?
Thank You,
FB
Thank You,
FB
