Is it possible to change this line into Construction Line so that three region has become one region for extrusion purpose?
You can either use the trim command to remove those sections or you can split the long line & make the middle section construction or make the whole line construction & then add two short lines on topadding relations to the end points or you can leave as is & select the three closed regions using contour select.
If you still want to split, then right click on line in the sketch mode and select from the pop up menu
