Ive been try to make these 2 circle connect with an r60 arc but i cant seem to make them join properly to be able to extrude them? its says they relations on them but the repair sketch tool says there are gaps?
Hi Johnathan
It works for me with a variety of extrude options. Im guessing the problem is your mirror, I used equal here. Also the sketch is not fully constrained, so that will make it harder to work out what wrong. I added a midpt rel to origin. The sketch is a mixture of open and closed, can you use trim? That would force the points to merge, or show you where the gap is?
I didn't get any error message when I closed the sketch and selected the Boss-Extrude tool, and it extruded fine after I had selected all the areas. And I agree with Rob Edwards about defining your sketch.
Jonathan,
I think you're actually connected. Try trimming out the inner portion of the two circles. SW wants to see a single profile.
Error message ...
No error message ...
