I just started using Weldments and noticed there's only three pre-drawn weldment structure size for Rectangular Tubing. Is there something I can download and add onto the folder to increase the selection? Or do I have to create as I need it? Thanks!
You can easily copy the existing sketches in the folder and rename them for other sizes. You have to open them thru Solidworks open dialog with either all files selected or library feature part in the file type. Once you open them simply change the dimensions for the driving sketch.
Hi Vincent,
You should be able to download a lot of standard profiles. Check out this page http://www.javelin-tech.com/blog/2015/04/download-solidworks-weldment-profiles/#.WCspqVWLRhw
