Property Name column is empty when in Configuration Properties/Custom Properties/Configuration Specific. I am using 2017, can someone tell me how to populate it?
***Edit
When I select the dropdown list it is empty, there is nothing to select. I need to know where the database is so I can point to it.
******************Edit******************
I found the list data, but I don' know how to point to it. This is new 2017 install.
Anybody????
Is this the file that SolidWorks keeps whining about when you right click a dimension and select Configure Dimension? In that case you can set SolidWorks to look for the file in the Options > File Location > Custom Property Files.
By default it's located in C:\ProgramData\SolidWorks\SolidWorks 201x\lang\english
Turned out it was broken with my installation as well, I was able to fix it this way
