Can I copy 3D sketch in order I can use it at the same Part? I need two sketches which are placed with an angle 106 degrees. These two sketches will be a base for two Sweep. I need the 3D sketch (I don't need just a body ) to continue modeling.
Thank you for tips and your time. I will sort out and study this.
I tried to save in a New Part and Save a body. It doesn't work for me.
I tried your proposition "inserting a part (with your 3d sketch) into another part twice and using move copy bodies"
I didn't manage to mate in a Part two sweeps, it is much complicated for me compare with Assambly .
I generally try and make a surface or solid body to rotate which I later delete when I want to do something like this.
but it would be possible to do it this way by inserting a part (with your 3d sketch) into another part twice and using move copy bodies
