I want to repeat this bolt to other three holes. In the property manager window I couldn’t see any space for that. What is the reason for that?
You need to click on the little blue arrow to go to the second page of the feature.
By the way, if you're just wanting to learn how to use the "Copy with Mates" feature, that's fine, but otherwise the Pattern Driven Component Pattern is a more efficient way of placing that hardware.
assuming the holes were made with a feature pattern, or hole wizard.
My preferred method!
It is very easy. Thank you very much for introducing this method.
Copy with mate is not coming I do not why. I am able to place the bolt in one hole only. I am trying to find out the reason.
The only thing I have seen stop copy with mates is when the part has an un-supported mate.
Could you tell me please what is meant by "un-supported" mate?
not all mates are supported by the copy with mate command
I found concentric mate is supported by copy with mate command. I have to find other.
