Can I assign a parameter to the slot length in the Hole Wizard? I tried putting dimension reference in the Hole Wizard window (e.g. D6@Sketch3, and =''D6@Sketch3''). And I tried to Configure the Hole Wizard feature (can only un/suppress)... I could just ExtrudeCut the slot, but not sure if SW has a secret way.
Jesse
After creating and closing the Hole Wizard feature, you should be able to double-click (or single-click if you have Instant 3d turned on) on it in the tree to show the dimensions in the graphics area. Double-click on the slot length dimension to bring up the standard dimension dialog box where you can link to another dimension, global variable, etc.
