Hello All,
I am using SW 2015 and have a issue when I Smart Dimension. When I select the item to be dimensioned the Modify box pops up. However it is the top entry that is highlighted and not the units.
I have never seen this before and it is super annoying. Just takes that extra button click, but I know that the unit dimension should be highlighted.
I recently moved into this computer, it is a Win10 Home Edition. Is there a registry that needs to be set?
Thanks in advance
-Jason
Hi Jason,
What service pack are you running? This was changed in a later service pack or SOLIDWORKS 2015 so that the dimension value is highlighted by default rather than the dimension name. Unfortunately, I am not sure exactly which service pack of SOLIDWORKS 2015 this was changed in, but I did test SOLIDWORKS 2015 SP05 and it highlights the dimension by default. Therefore, I would suggest you upgrade to SOLIDWORKS 2015 SP05 or later to resolve the issue.
I hope this helps,
Jim
