First, edit your Sweep3 and de-select "Merge result". That will create this Sweep as a separate body instead of blending it with the rest of the Part. Do the same for Boss-Extrude8 (at least I assume you want it mirrored also).
Next, you'll need to edit LPattern3. De-select "Features and Faces" and choose "Bodies" instead.
Now you'll be able to Mirror the bodies. Again, make sure you have "Bodies to Mirror" selected instead of "Features to Mirror".
