Is there a way to remove steps from nonlinear result files? The files are large but I only need results from the last step. Or must I re-run and change the settings under "result options"? Thanks.
In thoery, changing the result options and re-run SHOULD do the trick; HOWEVER, I would delete all Simulation results files and re-do the study just in case (but that's just me playing it safe).
If you are trying to reduce file size, I'd recommend using Pack & Go, check the "include simulation fales" and .zip it!
Regards,
GF
