Hi all,
how can i Combine 2 macros?
thanks
Yes you can but depends on what their functions are and what you need.
Share your macros here and someone would guide you through.
Check this would help
Option Explicit
Set swModel = swApp.ActiveDoc
If swModel.CustomInfo("Rohteil") = "" Then
MsgBox ("please enter value")
Else
'Force rebuild
swModel.ForceRebuild3 True
'Re-draw graphics window
swModel.GraphicsRedraw
'Save active document
swModel.Save
I have a similar situation, I am trying to re-write / combine 3 macros
The first is to transverse through an assembly and any sub-assemblies, fixing in place all assemblies and components :
it's this one from Wayne Matus
Option Explicit
Dim swModel As ModelDoc2
Dim swAssy As AssemblyDoc
Set swAssy = swModel
TransverseComponents swAssy
swApp.SendMsgToUser "Done!"
Sub TransverseComponents(swAssy As AssemblyDoc)
Dim vComponents As Variant
Dim i As Integer
Dim swComponent As Component2
Dim swAssembly As AssemblyDoc
vComponents = swAssy.GetComponents(True)
For i = 0 To UBound(vComponents)
Set swComponent = vComponents(i)
Set swModel = swComponent.GetModelDoc2
Debug.Print swComponent.Name2
swComponent.Select4 False, Nothing, False
swAssy.FixComponent
If swModel.GetType = swDocASSEMBLY Then
Set swAssembly = swModel
TransverseComponents swAssembly
Next i
That works great. I want to suppress all the mates at the same time though, rather than have them all just turn inactive.
So I was looking at the following 2 examples of how I might be able to do that.
2011 SOLIDWORKS API Help - Suppress Feature Example (VBA)
2011 SOLIDWORKS API Help - Get Mates Example (VBA)
I attempted to edit, then call-in the "get mates" macro, which then called-in an edited version of the "suppress feature" macro. I've discovered that doesn't seem to work like I thought it would, and I have no idea how re-write it into a single macro that does what I need. (I'd show my work but i'm too embarrassed to share.)
I want to start at the top level assembly, fix all the sub-assemblies and components, their internal sub-assemblies and components, potentially several layers deep, just like Wayne's macro does, then suppress all the mates.
To prevent myself from "moving the goal posts"; If possible, I'd also love to turn all of my equation driven dimensions into numerical entries, and then make all dimensions read/write instead of read-only. Since most equations are in sub-assemblies controlling their internal parts, when the selected from the top level, they're read-only but I'd like to be able to direct edit the dimension text from that top level. At this point in our work, the equations/functions/etc have already served their use and are obsolete. It would also work just fine if I could simply make the dims editable and where necessary, overwrite the equations as needed.
I can go into great detail of the why, including posting some example models etc, how we use them, and the next stage after running the macros if anyone is interested or the info helps creating a viable solution. I deemed this post wordy enough already.
thanks for any suggestions, and all assistance .
joe
Joe, I would suggest you to start a new post and put the requirements with an example stating that how this could be useful. This way others can also put in ideas/thoughts and can understand the usefulness of the method.
Further I would also suggest to go with standalone or add-in for a faster processing rather than a macro.
Thank you Deepak for your suggestion, I will certainly do that. It will take me a few days to put together some examples of a model starting point state, and then another of where I want to get to, along with why we need / like to work this way. There certainly could a better method to how we use Solidworks here and I'm completely open to looking at other work flow options. Your suggestion for considering a stand alone or add-in package is something that I thought of but have not seen an appropriate solution. If there is something already out there tailored for my industry (architectural millwork), I haven't found it yet.
The post will be lengthy to adequately describe our needs but I don't see a way around that, especially since I want to find the best method for us.
I also have a call in discuss this with my VAR (CATI) to see if they can help.
In other thoughts, I do have a number of macros I've cobbled together that do work nicely. Is there a place to share those with the community? Should I simply start a new post and share them that way? Some are tied back to excel files to import data, others are only for operations within Solidworks.
I've seen not any thing like that but it should be do able. I'll see if I can get some time over weekend.
Thanks for your great thoughts in sharing them. I would suggest you to post them under API section, each with a new post and also on the 3D ContentCentral website.
