Im working on creating an easy macro way of moving files into folders within a current working directory. The Active file path changes based on project folders in project directory.
So far Ive tried:
MyPath = CurDir ' doesn't work
MyPath = swApp.GetCurrentWorkingDirectory ' doesnt give me me correct directory jumps from previous folders ive used
MyPath = Part.GetPathName ' works but i need to cut off title by Part.GetTitle, but for drawings get title adds "- Sheet" which is a pain to remove since the sheet can be default or custom named depending on person creating drawings.
Is there a simple way to get active folder path?
Also is there a way to get drawing name without the sheet?
Once i get the active folder path, i can save a PDF into the \PDF's folder, send rev's to the \Revisions folder ect.
Thanks in advance,
Sebastian
Here is the code to get the document name and you can use the sub-string to get the path
