Only selected one wheel of the engine is rotating. What can be done to make all six wheels rotate and engine to move?
You mean manually using the mouse to rotate the part? if so, use gear mate
Your file is not opening. I want the engine to move back and forth.
It's straight forward
Basically, you can use the gear mate between 2 round parts and do the same for the rest
then when you rotate one part, the rest will be rotated with the one you select
I just attached the assembly of the train and tracks - see the results - Also try again the avi clip (open with Windows Media Player)
Thank you for the file. I am able to open your video file using Window Media Player.
I only applied the gear mate to 2 wheels but you can finish mating for the rest
