i am required to design a simple transmission case/housing. Creating the case will be simple using extrude and shell commands but as in typical transmission cases, I need to add a little material around where i will be placing the bolts and dowels to seal the case. Thanks.
Chris,
If you can build this model up to this point you should be able to add extra material around the edge by creating a sketch and extrude or revolve it
