I use the standard right view as the satrting reference in drawing, i want to get a relative view from a single component (not assembely)which is similar a Isometirc view, i tried all surfaces , the result is as a top, front or right standard view,
You can use "Relative to Model" view. Menu insert->drawing views->relative to model.
Using this function you can select from your 3D model which are the two planes or surfaces that re used to create a new view.
I won't recommend that for mainly two reasons:
Hi, dear Deepak, may u have look i attached screen shot, the view i want is not exact ISO view, i could use the rotate tool in drawing the get this is view, but what if the view i want may the specific request , ask related to some dimension.
Well simply create the required view in the model and insert in the drawing.
Here is post on how to create a new view orientation in model: Creating New View Orientation
The post is bit old but concept/process in same in recent/latest versions also. And once you've the view created, it would be available in the view palette in drawing. From there you can simply drop into the drawing.
