MRMarko Rebec04/11/2016
Hi everyone,
I am dealing with macro to rename parts filename in opened assembly.The name should be the existing name + some custom properties in each part.
I think I am missing something because I get through the assembly and read the component names but can not rename documents.I get un error on RenameDocument witch is consequence of NOT selecting properly with SelectByID2 (I suppose).I am posting the code if anyone can help.
Thank you in advance.
Sub TraverseComponentandRename(swComp As SldWorks.Component2, nLevel As Long)
    Dim vChildComp As Variant
    Dim swChildComp As SldWorks.Component2
    Dim swCompConfig As SldWorks.Configuration
    Dim oldName As String
    Dim newName As String
    Dim swSelData As SldWorks.SelectData
    Dim bRet As Boolean
    Dim swConfigMgr As SldWorks.ConfigurationManager
    Dim cusPropMgr  As SldWorks.CustomPropertyManager
    Dim swModelDocExt As SldWorks.ModelDocExtension
    Dim ValOut                  As String
    Dim ResolvedValOut          As String
    Dim wasResolved             As Boolean
    Dim lRetVal                 As Long
    Dim status As Boolean
    Dim errorsRename As Long
    Dim sPadStr As String
    Dim i As Long
    For i = 0 To nLevel - 1
        sPadStr = sPadStr + "  "
    Next i
    vChildComp = swComp.GetChildren
    For i = 0 To UBound(vChildComp)
        Set swChildComp = vChildComp(i)
        Set swChildModel = swChildComp.GetModelDoc2
        Set swModelDocExt = swChildModel.Extension
        'swCompConfig = swChildComp.ReferencedConfiguration
        Debug.Print sPadStr & swChildComp.Name2
        ' Changing component name requires component to be selected
        bRet = swChildComp.Select4(False, swSelData, False)
        oldName = swChildComp.Name2
        'Debug.Print oldName
        Set swCompConfig = swChildModel.GetActiveConfiguration
        Set cusPropMgr = swCompConfig.CustomPropertyManager
        lRetVal = cusPropMgr.Get5("Pozicija", False, ValOut, ResolvedValOut, wasResolved)
        Debug.Print "Pozicija:          "; ResolvedValOut; lRetVal
        'swChild.Name2 = newName
        status = swModelDocExt.SelectByID2(oldName, "COMPONENT", 0, 0, 0, False, 0, Nothing, 0)
        Debug.Print "Staro ime: " & oldName
        newName = ResolvedValOut & "_" & oldName
        Debug.Print "Novo ime: " & newName
        errorsRename = swModelDocExt.RenameDocument(newName)
        Debug.Print "Rename document errors: " & status; errorsRename
        TraverseComponentandRename swChildComp, nLevel + 1
    Next i
