library feature with design table?
Question asked by Rico Kunst on Nov 4, 2016
Latest reply on Nov 7, 2016 by Rico Kunst
Hi guys,
For retaining plates I use a company standard to position holes depending on the applicable shaft diameter as shown below.
Now I was thinking if it is possible to create a library feature for this hole set. Because location and size of the holes is defined by the shaft diameter it should be nice for an user to select the applicable shaft diameter from a list or combobox and let SW set the correct dimensions. Maybe a design table can be used for this?
Do you have any ideas how to get this work? Or are there other alternatives to do this?
BR,
Rico
