Cut sweep a blade path
Question asked by Jeff Dickson on Nov 1, 2016
Latest reply on Nov 18, 2016 by Paul Salvador
Hello All
Today's challenge :
I'm looking to sweep what is a blade path which can rotate along an axis leaving a "castellated cut" which is what our more fancy machines can do.
Attached picture shows a 10mm blade rectangle , it central axis which does not change and two guide paths which would result as the blade rotates about the central axis.
Being able to do this cut sweep would be super handy as we experiment with blade paths
As you can see in the other picture the sweep path will work but SW changes the paths from the desired square path to a nice smooth parabola type thing !
Any help or suggestions much appreciated
JD
