Hello all,
I am currently designing some new templates and can not figure out how to work the save function in the title block editor.
PROBLEM 1: Note Not appearing
Note is not appearing in block
when i go into edit block mode note appears
PROBLEM 2: block edits don't appear in all modes
when i edit in block edit mode the change appears in block edit mode
but not in edit sheet format mode or edit sheet mode
PROBLEM 3: which way is the correct way to save a block
Should i save in edit block mode where it saves a block but changes are only seen in edit block mode, not in normal edit sheet mode where it actually needs to be seen
Or
should I double click the field i want edited, make the change then save block in the edit sheet format mode where changes only apply in the edit sheet format mode but not the edit block mode.
I'm just really confused at this point and any help would be appreciated.
