1-6B8PWQ
Appearance of objects in PhotoWorks
Discussion created by 1-6B8PWQ on Oct 10, 2008
Latest reply on Oct 10, 2008 by Mark Kaiser
I have drawn some models in SW and wants to make some high quality pictures and animations in PhotoWorks. When I activate PhotoWorks everything turns gray and it seems like all appearance data added in SW is not taken into PW. Do I realy have to add all appearences once more in PW ore is there a way to "import" appearance data from SW and just edit the surfaces that should have higer surface finnish.
What is the best procedure if you are to use the models in PW, draw everything in SW and then activate PW to add surface data ore just have PW active trough the whole process and add textures as you draw?
