When dimensioning holes with center marks, is there way to avoid selecting the center mark lines without having to zoom in in order to specifically select the geometry around it. And, also, why would there be an ability to apply an angle dim to a center mark. Why would such a thing be needed, at least the way default center mark lines appear. The times I do need the type of angle shown I would rather create construction geometry and dimension to that. Or purposely lengthen a center line and dimension to that. I know in the drawing options center marks can be excluded on drawing creation. But when receiving drawings from others, it seems like many times I'm putting angles on the marks, or zooming in and out to pick geometry only, or just going through and deleting them all together.
I would uncheck this option - I was thinking there is another one as well..... but try this
