In the tutorial two teeth are not there. Is it possible to eliminate these two teeth in my sketch?
yes,.. when editing your pattern... at the bottom is instances to skip... see attached image..
speedy
Use the instances to skip feature in the dialog box. Then sick the points you want to skip.
Thank
