When i try to measure an angle or distance between an edge of a view and a sketch line in drawing, use smart dimension, if i choose the edge, then it not allow me to choose the sketch line, opposite, the same, is it because of dimension setting in drawing or other issue?
This is because line is not attached to that view.
Select the line and do copy or cut. Then click on view and paste. And then you can do the measure/dimensioning as deed (like they've asked in the drawing exam )
