Hello.
I would like to now if is it possible convert a surface to solid, because i want to cut a part from the other, in order to have in the final a cavity, it's possible?
Regards,
Daniel Vicente
Regards,
Daniel Vicente
Of course the surface body has to meet certain rules for solids, and you should run all of the checking routines to make sure the geometry is good (tools, check, as well as verification on rebuild +Ctrl-Q)
You can also use one solid to cut another. Creating a part from a mold cavity might be tedious using surface functions. For multibody see Combine. for assembly see Cavity.
