Hi. Would it be possible to run SolidWorks 2015 student edition on this computer: https://www.power.dk/pc-og-tilbehor/barbare-computere/barbar-pc/asus-r417sa-wx022t-14-barbar-bla/p-259025/. I'm worried because it only has 32 GB disk space and 2 GB ram. Would it even be possible? Maybe with an external HD? Cheers, Oliver
I'm pretty sure you won't be able to install SW at all. Go look into the requirements and it says you need 8gig of Ram and 5gig disk space to run. I've seen SolidWorks run with 4 gig of ram but it's not a really workable solution because you quickly find yourself with memory problems as your models gets bigger.
So unless you can switch to OnShape instead of SolidWorks this machine won't be able to do CAD.
Patrick
