We have large assemblies which have multiple configurations. Often we have a "Simple" config in which alot of the components are suppressed. If we launch this assembly from the Solidworks open dialog, there is an option to select which config to launch. We can then select the Simple config which then loads alot quicker that any of the others.
I seems we cannot do this from the EPDM interface. Does any one know of a way to specify which config to launch when opening assemblies from the EPDM interface?
If the file is not cached on your local vault image this option is inactive. If you want to select the configuration you must first do a get latest version.
