Going from DT Driven to Parametrically Driven
Question asked by Alan Stoldt on Oct 9, 2008
Latest reply on Dec 11, 2008 by Jason Capriotti
I have a Profile Rail and Bearing set-up in an Assembly Driven by a Design Table (see images below).
The Mounting Holes on the Rail are at a 60mm Pitch, and then ends of the rail should be 20mm from CL of a Mounting Hole.
Our cylinders used with these rails are Inch. The Minimum Sized rail I can have is 100mm Lg (2 Holes ~ 100-60 = 40 /2 = 20).
For every two Inches of stroke, the rail grows by 60mm in Length and (1) Hole.
1" and 2" Stroke = 2 Holes = 100mm
3" and 4" Stroke = 3 Holes = 160mm
5" and 6" Stroke = 4 Holes = 220mm
etc...
I am able to accomplish this with a Design Table driving the Assembly.
What I am looking to do is tie the Assembly into a Layout Assembly where the Stroke would be Input. (Currently Stroke comes from the DT)
"Adder@Sketch1@25mm_Hi_Pro_Rail.SLDPRT" = "Stroke@Sketch1"
So I am hoping for an equation where :
"Adder@Sketch1@25mm_Hi_Pro_Rail.SLDPRT" = xxxxx
If the stroke is 1 or 2 then Adder is 60mm, if the stroke is 3 or 4 then Adder is 120, etc.
Any help in writing this equation is appreciated.
Thank you in advance.
